Help with WD Hydraulic
dairyhill
05-05-2003 10:30:35
Looking in the origanl manule for the WD I saw in the parts part that there can be a third line for a remote line that will let you raise and lower a pull implents. The only thing I can't finger out is where it hooks into the pump? or do you have to disconneted one of the other lines. The reason I want this is I am builing a small disk with wheels to go with it since I got the WD pick-up plow and a two row cultivator. any info on this would be helpful. Thanks.
JMS/MN
05-06-2003 22:39:33
 Re: Help with WD Hydraulic in reply to dairyhill, 05-05-2003 10:30:35
Two outlets should have lines going to the lift cylinders, the available one is the one you use to hook to the remote valve. AC had a steel line which hooked directly into that port, and came back along the steering column, above the differential, and to the remote coupler.
wdTom
05-05-2003 17:16:03
There are 3 plugs or outlets on the top of the hydraulic pump/unit. One, and I don't know which is for the rear or romote cylinder.
