WD 45 overhauling prices
ken
03-24-1999 14:18:09
I want to overhaul my Wd 45 and put oversized pistons in it. I saw an ad that had a totaly overhauled WD 45 engine with oversized pistons in it, but he wanted $1600. Is this to much?? How much does it cost these days?? I need to do something soon, mine smokes realy bad. Any help will be greatly apriciated.
Thanks
Ken
The guy that has the engine said that it is compleat except for the manifold, carb., and the fanblade. He has also started it to cheak for leaks.
AL
03-26-1999 09:38:56
 Re: WD 45 overhauling prices in reply to ken, 03-24-1999 14:18:09
I HAVE A D17 MOTOR IN A WD45 WITH LOTS OF HOURS NO PROBLEMS
mark
03-25-1999 11:52:54
why not upgrade to d17 parts
mm
03-25-1999 15:28:59
 Re: Re: WD 45 overhauling prices in reply to mark, 03-25-1999 11:52:54
The problem is the D-17 has the G-226 engine and while it is rated at 67 hp at the flywheel and give th D-17 53 PTO hp it could be too much for the WD45's wet clutch. It is a DOMINO effect.
orangeman
03-25-1999 08:58:16
1600.00 is not too much for a complete overhaul which I believe the engine of which you are speaking has had. I have 1700.00 in the last engine I had done. When I say complete I am talking about re-surfacing the head, the block and turning the crankshaft, new cam shaft bearings etc. On wd-wd45 blocks it is critical to make sure the o-rings on the wet sleeves seal correctly, that means some work may have to be done in this area. There are overhauls and then there are complete rebuilds, such as this engine. You can do it cheaper and it may or may not do the job. My thoughts are, if you are going to all the work, why not do it right?
oly
04-04-1999 21:22:43
 Re: Re: WD 45 overhauling prices in reply to orangeman, 03-25-1999 08:58:16
the orangeman is correct, if you are going to go to all the trouble, why not do it right.. good luck oly
mm
03-24-1999 15:38:14
Hi, Are you sure your WD-45 needs an overhaul. I'd run a compression test first, myself before I would jump in that deep. If is has say 110 to 140 psi compression. I would have valve guide seals installed without removing the cylinder head. This about two hours with good help. It can make the difference of a fouling spark plugs.
