WD tie rod ends
Gregory K Soder
05-04-2003 15:36:06
Does anyone know if tie-rod ends on a WD are pressed into place, then castle nutted? I'm trying to get the old, left side ones out and it seems I might need to get a tie-rod end puller?
Brian G. NY
05-04-2003 16:55:51
 Re: WD tie rod ends in reply to Gregory K Soderberg, 05-04-2003 15:36:06
They are a tapered fit like most tie rod ends. Loosen the nut a few turns, put a sledge hammer on one side of the eye thru which the bolt fits and strike the other side SHARPLY with a heavy hammer; should pop right loose. I like this method because it is quick and in those cases where you want to reuse the tierod end (or it's rubber boot) they are not damaged like they can be when a "pickle fork" is used.
