Re: A bizarre problem?
Ron
03-24-1999 11:32:54
Have you tried a new plug, or checking the gap? I would also try swapping the plugs and/or wires from #1 to #4. This will at least tell if it is a plug or a wire before you buy anything else. My $0.02. A dirty plug will sometimes not fire at low voltage, but when you hold the wire 1/4" away, you increase the capacitance between the coil and ground, causing the coil voltage to rise and when the spark jumps that gap , it has enough energy to also jump across the plug gap before it all leaks away through the dirt on the plug.
