Company Logo (800) 853-2651 Shop Now
Re: A bizarre problem?
Ron
03-24-1999 11:07:22
Have you tried a new plug, or checking the gap? I would also try swapping the plugs and/or wires from #1 to #4. This will at least tell if it is a plug or a wire before you buy anything else. My $0.02. A dirty plug will sometimes not fire at low voltage, but when you hold the wire 1/4" away, you increase the capacitance between the coil and ground, causing the coil voltage to rise and when the spark jumps that gap , it has enough energy to also jump across the plug gap before it all leaks away through the dirt on the plug.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 706 gas fuel tank&radiator [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
