Locating year and model
Lee Jenkins
05-02-2003 19:15:46
I need to find the year and model of an Allis-Chalmers from a set of numbers. I found three numbers on vehicle, one on the trans case is 221826; one on the axle, AM3635-10; and one on the brake pedal, AM 4469. Help..... ...
steve
05-03-2003 05:29:32
 Re: locating year and model in reply to Lee Jenkins, 05-02-2003 19:15:46
if it was made 1940-1960 and is a small tractor (24 inch diameter rear rims) the serial number is by the transmission shift lever (model B or C or CA), if it has larger rear wheels, and probably a c-channel side frame around the motor, the number is probably on the rear axle by the left brake cover (WD, WD45). IF it was made after 1960, probably a D series and the nuber is on left clutch (torque tube ) cover, just behind the motor, on a flat boss. Normally starts with D10, D12- etc. IF it was build in the 1980 era and is made oveseas, that is another story.
