Re: Allis Engine in Farmall
Zonie
05-02-2003 18:34:38
I belive if you were to put an allis wd or wd-45 engine in a farmall m that you'd be disappointed as I belive the farmall engine has greater torque even though the horsepower is close. I have a farmall H and an allis WC( same basic engine as a WD) the flywheels look to be about the same size and the cluches will interchange. It might be easier to put the WD engine in to a farmall H and you might be happier with the results. the H tractor weighs around 1000 lbs less than an M.
