Re: AC B NAPA paint code? Urethane?
John in NC
05-01-2003 20:10:14
third party image
I used NAPA acrylic enamel on my 39' B restoration. It is Martin Senour 99L3723 which is Persian #1. It was easy to apply and came out nice. Make sure and get the hardener and use their reducer also. You will need at least 1 gallon to do a proper job on the tractor. I do not know the difference in the Urethane paints. The enamel can be affected by gas if it is left continuously exposed like a fuel leak, etc. A spill that is cleaned up does not seem to be a problem. I have a picture of the finished paint job attached..... ..Good Luck, John
