WD Headlight replacement bulbs?
Bones Magoo
04-30-2003 14:26:50
Ordered a set of O.E.M. style headlights from AC Vendor on the net. They came set up for the original 6 Volt system, with bulbs stamped 6V21CP which I think means 6 volt 21 candle power.
My tractor has been converted to 12 volts, and am wondering if anybody knows of a good replacement bulb to use?
I've been to NAPA, and after consultation with parts guy, purchased a set of automotive type bulbs intended for marker lights, turn signals, etc. They are supposed to be rated at 32 candle power. These aren't very bright, and I'm wondering if anybody here has a suggestion as to a nice bright 12 volt bulb to use in the original style headlights?
Thanks for any information or suggestions!
Good Day!
Steve in N.J.
04-30-2003 17:35:18
 Re: WD Headlight replacement bulbs? in reply to Bones Magoo, 04-30-2003 14:26:50
Bones, How bright are you looking for? Do you want a flood type lamp, or a Halagen? I can probably set you up with whatever you want. I have a couple styles I keep in stock for 12V change-overs. Drop us a line if interested.....
Steve/B&B Custom Circuits
JDWNY
04-30-2003 15:08:51
I THINK THE ONES YOU USE IN A D17 WOULD WORK THEY ARE 12 VOLTS
