CA hand clutch
Jeff Mueller
04-29-2003 19:22:18
Does anybody know how to get it out?
We have the axle off, we can see the pressure plate, but we don't know how to get it out.
DanD.
04-30-2003 14:43:50
 Re: CA hand clutch in reply to Jeff Mueller, 04-29-2003 19:22:18
THe other post advising a service manual is good advice. Once the axle housing is off and you're looking at the clutch assembly, you can just pull the clutch right off the axle. Now, it may be rusted on a little so a lot of penetrating oil and a little bit of prying may be in order. Also, I assume you must be removing it because it's slipping. Make sure that the metal balls and seats are in good shape. THey tighten the clutch plates together when under load and are actually more important than the clutch springs. THis is called a Lambert (spelling?) clutch as opposed to the more typical clutches seen on the engine.
JMS/MN
04-29-2003 21:11:01
Get an I&T or similar SERVICE manual for details on how to do R&R on your tractor.
Jim Z
05-04-2003 13:24:57
 Re: Re: CA hand clutch in reply to JMS/MN, 04-29-2003 21:11:01
I have done several. And have never been able to just side the unit out. The IT shop manual tells you t remove a clip But in order to get to the clip you have to remove the clutch first.So the manual will do you n good. You have to evenly remove the 6 allen head cap screws first. Then remove the clutch. Everthing must be free of rust The 3 steel balls are very important After cleaning every part put a LIGHT film of grease on the balls. Even a worn disc will not slip if everthing is clean & working properaly.
