Jeff Banks
04-28-2003 11:33:20
Is there a way to get a serial number from a D-12 other than the one on the motor ?? I purchased one that has a new motor but would like to know the year that it was manufactured.
Kevin (FL)
04-28-2003 13:49:16
 Re: Serial Numbers in reply to Jeff Banks, 04-28-2003 11:33:20
Jeff,
The tractor serial number should be stamped on the torque housing, left forward near where it mates to the engine. On my D17, the S/N begins with "D17" and then the number and it's on a "flat" area of the torque housing. It's on the part that is sloped at about 45 degrees--right above one of the engine-to-tube connection bolts. Not sure, but I think the D12 S/N is found at the same location. The engine number is located on the left side of the block.
