Gasket between the tank and mounting bracket?
Mike
04-27-2003 21:57:18
My father and i are starting to both restore a 1948 c and a d15. We are wondering wear to find the gasket (proably not the right name for it) that goes between the gas tank and the bracket it mounts to. I belive it is so the tank and bracket dont rub together and wear a hole in them. Can you still by the original material and where from. Or if you cant what has people used between them. Any help would be apprecitated alot. Thanks
fisher
04-26-2004 00:10:26
 Re: Gasket between the tank and mounting bracket? in reply to Mike, 04-27-2003 21:57:18
the G i own has tire sidewalls cut to fitbetween the straps and tank.
Mike
04-28-2003 21:12:13
Thanks to everyone for the information and ideas. It is very helpful. I will talk to my father and see what he wants to use. I belive this is the best web site i have ever visited. Thanks again.
Mike
Harold
04-28-2003 19:32:01
I used an old seat belt on my WD45. Worked good.
Mike (MA)
04-28-2003 17:07:02
I purchased a short length of 1" white nylon webbing used for rock climbing from Eastern Mountain Sports. It looked exactly like the original only in much better condition. If I recall correctly, a 1 foot section cost about $1.
Mike
steve
04-28-2003 15:21:01
use a piece of inner tube. will not get wet and hold water aginst the steel tank.
Terry
04-28-2003 14:29:37
I used a leftover piece of yellow tie-strap that I cut off from a ratchet tie down that was too long. Works great.
Rod
04-28-2003 10:46:25
I used a piece of campershell tape on my WC. Works great and has been there for 6 years.
Tom Westerfield
04-28-2003 10:23:33
I'm with Jason. I stop by the local "army surplus" store and buy their webbing. It works perfectly. In a pinch I've used short pile indoor/outdoor carpet that has a jute back. It works good too.
Bill
04-28-2003 09:21:08
Mine had a piece of warp tape. I would believe that that was the original. It can be bought in ost mechanical supply houses as it is used as a gasket on vessels.
AWB
04-28-2003 05:39:21
Go to your nearest fabric shop or to your nearest upholstry supply shop and you can usually find a piece of canvas webbing that is the right width and you don't even have to cut it except for length. Worked great on my last restoration!
Tyler(WA)
04-28-2003 00:11:11
Mike, I'm restoring a '38 B and was suprized to find the existing "pad" was cut from an old inner-tube.
May not be what Allis Chalmers used but who's going to know? That part isn't scrutinized in even the most picky shows.
I was amazed at how well the pad held up too.
Steve in N.J.
04-28-2003 18:49:54
 Re: Re: Gasket between the tank and mounting bracket? in reply to Tyler(WA), 04-28-2003 00:11:11
Mike, I have the correct gas tank welting in a kit form for the B/C machines. The kit runs $9. + shipping. If you need it for the D series measure the lengths you need for that and I can cut them off the roll to the size you need. Drop us a line if interested....
Steve/B&B Custom Circuits
jason
04-28-2003 05:43:59
i used a milatary style web belt and took the buckle off and cut to length. just about the same as original on my wc. jason.
david l wilson
04-27-2003 23:39:32
mike when i did my d17 i went to j.d. and bought a piece of[ canvas i think] that they use for the same place. it was wider and i had to cut it down to fit but beter than nothing. good luck david l wilson
MIKE D.
04-28-2003 04:01:27
 Re: Re: Gasket between the tank and mounting bracket? in reply to david l wilson, 04-27-2003 23:39:32
I had the same problem with a WD and I cut a strip from an old exercise tread mill belt. works well and looks great.
