AC/C narrow to wide front
ralph bentley
04-27-2003 11:45:54
what is involved when changing ac/c narrow to wide front the wide front is adjustable from a ac/b does anybody know if the b bolts on the front of the engine same as the c?i know the tie rods are differntbut i can over come that problem any help out their thank in advance R.E.B.
Sam F.
04-28-2003 19:28:24
 Re: AC/C narrow to wide front in reply to ralph bentley, 04-27-2003 11:45:54
Ralph: I just purchased a CA with a wide front off a JOHN DEERE "B". It works!!
Edward Mills
04-28-2003 07:29:00
This article is really an online book which I have found to be most useful and interesting with regard to AC B and C tractors - you might find the comparison of parts in Chapter 7 of help.
http://www.ytmag.com/articles/acbook/
Tyler(WA)
04-27-2003 12:46:13
Eldon's right on the money. The C narrow front uses a gear box with a reverse twist on the worm gear because the steering arm goes up instead of down like the wide front uses.
You also are going to run into a problem with the front steering mount. It's very different for a narrow front. I know a guy in WA that's looking to restore a C to narrow front and has the wide front setup. He has the front axels but needs the radiator mount/axel support for the narrow, he has the wide front style. I'll hook you up and you two can swap parts for the freight, if you're interested.
Eldon
04-27-2003 12:12:02
I'm sure they will bolt right up....but to make it look decent I would put on a B stearing gearbox...otherwise the stearing rod won't be straight or it will stear backwards.
Kip Hansen
04-28-2003 15:48:33
 Re: Re: AC/C narrow to wide front in reply to Eldon, 04-27-2003 12:12:02
You will need the plate that bolts to the front of the engine, the steering box, & draglink off the B & everything will bolt right on. Helped one friend do a CA that way, & just helped another friend adapt a C wide front to a B. The only thing that was not strictly bolt-on for the B was triming the radiator shroud to clear the front gearbox.
