Sparks at ground connection on AC B
Eric
04-26-2003 15:55:58
I've been having probs today with my B. It started but ran rough. I couldn't figure out why. I was running it around the yard a bit to see if it would clear up, then I think I ran the fuel tank dry. So I filled it up but no luck restarting.
Now for the kicker... during my starting attempts I noticed that sparks started coming from the bolt that connects the ground to the steering post. The sparks don't happen at every crank but were fairly consistent. My system seems to be 12volt negative ground.
Anyone have ideas?
Thanks,
Eric
Doug in OR
04-26-2003 16:51:04
 Re: Sparks at ground connection on AC B in reply to Eric, 04-26-2003 15:55:58
If it is 12 volt negative ground, it was modified somewhere along the line. This tractor originally was 6 volt, positive ground.
As for sparks - this is a sign of a poor ground connection. Completely remove the cable at this connection. Clean the paint and corrosion down to bare shiny metal. Now clean the terminal on your cable. Reconnect everything, using a good clean bolt. After all this, paint or otherwise weatherproof this connection.
Now when you crank the tractor, you might notice a day and night difference in how fast the motor spins. BTW, this is a very common electrical problem. Many overlook it when troubleshooting - they aren't given the tell-tale sparks to bring this to their attention.
Eric
04-28-2003 20:20:17
 Re: Re: Sparks at ground connection on AC B in reply to Doug in OR, 04-26-2003 16:51:04
Thanks for the tip. It did the trick.
Eric
Steve in N.J.
04-26-2003 19:13:34
Eric, Doug is right on the money there. After your connection at the ground is cleaned and re-attached, a little dab of Dielectric grease will keep moisture out, and keep the connection corrosion free. If you think you may need a new cable, we have them available...
Steve/B&B Custom Circuits
