Allis D-15
Chris C.
04-26-2003 15:32:16
My brother has aquired a 1961 AC D15 in need of some TLC . In addition to the throttle lever on the right side of the steering column there are two lever to the left of the column that control shafts that run into the top of the transmission housing, as well as a long lever on the right side coming up by the floor board. None of these are for the loader, I know Allis- Chalmers had a "power director" setup. Can one of you AC guru's enlighten a Massey Ferguson Man? thx in advance
Gordon-(TN)
04-26-2003 20:16:52
 Re: Allis D-15 in reply to Chris C., 04-26-2003 15:32:16
the two levers to the left of the stering wheel are,top is traction booster (works like draft control) on Massey, bottom is lift, the long one on the right side with button on top is the power director low side is when it is pulled back,the lever on left side by the clutch is for power take off. let me know if I can be of any help.
Gordon-(TN)
Chris C.
04-27-2003 15:15:59
 Re: Re: Allis D-15 in reply to Gordon-(TN), 04-26-2003 20:16:52
Thanks Gordon. I may tap on your expertise in the future, as this project moves along. Right now, the engine is out for new sleeves (2 cracked) and some general long neglected maintainance. At $100 with a loader and box scrape I don't think he can get burned to bad!Thanks again
