Can This blade be tilted?
Al
04-24-2003 19:52:32
third party image
Link
Probably>Link a stupid question, but how else can I find out without showing how little I know?
I can see how to angle, but it also looks like it's made to tilt.
If so, How?
Here is the address of the pic
http://groups.msn.com/AlandEricSanford/shoebox.msnw?action=ShowPhoto&PhotoID=23
Butch(OH)
04-24-2003 20:19:26
 Re: Can This blade be tilted? in reply to Al, 04-24-2003 19:52:32
The upper link on the right side should be threaded and adjustable by turning with the bent rod already in the hole. This tilts, or angles the blade
Al
04-24-2003 19:59:37
Here is a clickable link to the picture of Blade
Jack
04-24-2003 21:21:11
 Re: Re: Can This blade be tilted? in reply to Al, 04-24-2003 19:59:37
As Butch said the bent rod in the brace going to the top of the blade is your adjuster. You have one on each side and can get a lot of tilt(no angle) by going one way with one side and the other way with the opposite side. These things can really get hard to turn over the years if they haven't been used. Some have grease fittings-might see if you can located any. Jack
Al
04-25-2003 08:18:26
 Re: Re: Re: Can This blade be tilted? in reply to Jack, 04-24-2003 21:21:11
Thanks Guys,
I guess I see now how it is supposed to work, has anyone ever seen one of these modified to operate hydraulicly?
Al
steve
04-25-2003 15:20:10
 Re: Re: Re: Re: Can This blade be tilted? in reply to Al, 04-25-2003 08:18:26
yea, just replace the link with a tilt cylinder. might check wiht dealer, they were factory options on most tractors.
Al
04-25-2003 19:08:00
 Re: Re: Re: Re: Re: Can This blade be tilted? in reply to steve, 04-25-2003 15:20:10
Do you replace the top link on both sides?
steve
04-25-2003 19:39:50
 Re: Re: Re: Re: Re: Re: Can This blade be tilted? in reply to Al, 04-25-2003 19:08:00
one side with a 8 inch stroke cylinder would be adequate. two cylinders would be more complicated but give a much wider range of stroke. look at a local construction site, or equipment dealer and you will get the idea. dont matter what brand of tractor it is.
