Replacing front seal on CA
BWH
04-23-2003 10:09:30
I am replacing the front seal on my CA. I got the seal in but I have been told I need to be sure the timing cover plate is lined up correctly. It looks to me like I need to move it a little to do this. I loosened the bolts but the plate doesn't move. Am I doing this right or did I miss something? Do I need to loosen the oil pan? Thanks for any help.
Dick L
04-23-2003 14:08:03
 Re: Replacing front seal on CA in reply to BWH, 04-23-2003 10:09:30
Yup. and you should change the gasket. I would guess the gasket is stuck to the cover and or block.
BWH
04-25-2003 05:45:00
 Re: Re: Replacing front seal on CA in reply to Dick L, 04-23-2003 14:08:03
Thanks Dick, Got it done!!!
