WC clutch
Joe In Missouri
04-21-2003 07:22:16
I bought a WC this winter at an auction and the clutch stays engaged when you push the clutch pedal down, I don't know for sure where to start looking. Any sugestions before I pull the engine to see whats wrong?
JMS/MN
04-21-2003 21:53:48
 Re: WC clutch in reply to Joe In Missouri, 04-21-2003 07:22:16
I agree that the clutch is stuck to the pressure plate, but just driving it around is not going to loosen it- try hooking it to a stout tree with a strong chain, with the clutch pedal depressed. THAT might break it free, otherwise, it's dismantle time.
wdTom
04-21-2003 17:21:52
The clutch disc is stuck to the flywheel or pressue plate. Try putting in into high and driving around with the clutch pedal down, (disengaged), to break it loose. Open and close throttle briskly a few times. It may break loose. Some stick, some don't. I took my WD apart after it had set for 25 years and it wasn't stuck. Others stick after much less time.
Joe in Missouri
04-22-2003 06:21:57
 Re: Re: WC clutch in reply to wdTom, 04-21-2003 17:21:52
That will prove interesting trying to run it to break the clutch lose, it is hand crank start only.
wdTom
04-23-2003 17:32:41
 Re: Re: Re: WC clutch in reply to Joe in Missouri, 04-22-2003 06:21:57
Well that does add a bit of interest to the problem. Maybe you need to take out the engine, not all that hard to do if you have a way of lifting it.
