Packing behind Packing Nut on PTO -- Question about it.
Scott
04-20-2003 15:17:00
I have removed the PTO shaft from my 1936 WC and in the process I also cleaned off some built up dirt/oil and have awakened a leak. Its coming from the PTO Packing Nut area, and before I tear into this I wanted to find out what I was getting myself into. What is the packing material, and what is the process of putting new packing material.
Also part 2 -- While I have the PTO shaft out I was wondering how to tell if I need to put in a new bearing in the Rear Bearing PTO Housing. What kind of test should I use to determine if it is worth replacing. The shaft turns freely without any grinding, and it was full of grease when I tried greasing it for the first time.
Thanks..... .
Joe M
04-20-2003 15:55:39
 Re: Packing behind Packing Nut on PTO -- Question about it. in reply to Scott, 04-20-2003 15:17:00
Scott, I e-mailed you some pictures of the repair and the seal, also left a picture of the seal in "parts & pieces"
wdTom
04-20-2003 18:35:04
 Re: Re: Packing behind Packing Nut on PTO -- Question about it. in reply to Joe M, 04-20-2003 15:55:39
Could you just tighten the packing nut a little? Might stop the leak. As for the bearing, if it is smooth and doesn't make noise at speed and had grease you are OK. Just grease it once in a while.
