Hydraulic system on 5020
Rick A.
04-19-2003 00:00:35
could anyone give a suggestion on what my next step should be? the back hitch would not raise by itself. i cleaned the hydraulic screen and replaced the fluid. the hitch now raises, but will only raise with no implement attached. it is like it is not getting enough pressure to do the job. thanks for any replies.
Frank
09-08-2003 22:04:23
 Re: hydraulic system on 5020 in reply to Rick A., 04-19-2003 00:00:35
Did you ever get this problem solved, I have the same tractor with the same problem.
jackaerodecals
01-07-2006 19:13:43
 Re: Re: hydraulic system on 5020 in reply to Frank, 09-08-2003 22:04:23
I have a deutz d5006 someone put gear lube in the hydraulisc system . do you know how to drain the system or have any suggestions . it works but is slower at the pto. Jack
DenisB
05-01-2003 18:00:03
Have you checked the pump pressure?
It is at the front of the engine.
