Brake pins
TractorMike
04-18-2003 19:48:37
Well, after weeks of off and on beating I finally got my left brake pin out! It's amazing how long it takes to beat out 60 years of rust. When I got the pin out I had to get the old brake out and when I pulled out the old brake, It looked to be original. Now, my question is, where can I get new brake pins? Because I really don't want to reuse these pins. Thanks, TractorMike
Dave K
04-19-2003 12:50:56
 Re: Brake pins in reply to TractorMike, 04-18-2003 19:48:37
AGCO should have them.
Dave
TractorMike
04-21-2003 19:11:14
 Re: Re: Brake pins in reply to Dave K, 04-19-2003 12:50:56
Thanks, TractorMike
Tom(ID)
04-23-2003 06:31:34
 Re: Re: Re: Brake pins in reply to TractorMike, 04-21-2003 19:11:14
What tractor are we talking about here?
Tom
Tyler(WA)
04-18-2003 20:01:21
The brake pins on my B or C are easy enough to cut from cold rolled bar stock.
TractorMike
04-21-2003 19:12:10
 Re: Re: Brake pins in reply to Tyler(WA), 04-18-2003 20:01:21
Thanks, TractorMike
David Maddux
04-19-2003 03:48:15
Make sure you put antiseize on them before you put them back. There is no need for your grandkids to be cussing you some day.
wdTom
04-20-2003 18:43:18
 Re: Re: Re: Brake pins in reply to David Maddux, 04-19-2003 03:48:15
The pins for wds and 45s are case hardened. grind off a bit from the outter end and then drill and tap them for a 3/8 24 thread, then you can use a bolt or stud for a puller next time. I say a fine thread so you have more metal left in the bolt or stud, they can be a bit#$ as you found out. And it is easier to drill and tap them with them not in the tractor. I know. A lathe is best but you can di it with a drill press and vise or vee block.
TractorMike
04-21-2003 19:14:35
 Re: Re: Re: Re: Brake pins in reply to wdTom, 04-20-2003 18:43:18
Thanks, I might have to try that. TractorMike
