Allis Chalmer WD 45
problem starting
Paul
04-18-2003 14:01:48
I'm a rookie here so all the help I can get, Thanks. Well, I just purchased a WD 45 for some land tilling and now it's dead. It worked for awhile and then it just stopped. I resealed the block, got new spark-plug wiring house and all. Everytime I turn it on, it just turns over and over until the battery dies, and no start???? Any body knows what can be causing this. I changed oil, spark plugs, gasket, coolant....
JMS/MN
04-18-2003 17:35:34
 Re: Allis Chalmer WD 45 - problem starting in reply to Paul, 04-18-2003 14:01:48
If an engine has spark at the right time, and fuel, it should at least run poorly. Might be an obstruction in the fuel system, anything from some blockage in the tank or lines, or in the carburetor. If no spark at the plug, trace things back to the source- could be something as simple as a broken wire. If it sputtered and died, perhaps a fuel problem, if it just quit with no warning, it's often an electrical problem. Diagnosing what the problem is should be done in a logical sequence, rather than getting in to major teardowns or replacing things that don't affect fuel and spark.
