WC final drive seals
David Maddux
04-18-2003 04:26:06
I have installed all new seals on my final drives and still have a small leak. The new seals are rubber instead of cork. Would it help if the seals were coated with wheel bearing grease before installation? Dave
Joe M
04-18-2003 17:55:25
 Re: WC final drive seals in reply to David Maddux, 04-18-2003 04:26:06
I have had mine in for a couple of months with no leak, I did wet the spiral cut groove with a small amount if grease. Also, how thick of oil did you use? My book called for 250 wt gear oil, takes a pretty big place for it to begain to flow through, could you have torn the seal a little sliding it accross the hub?
David Maddux
04-19-2003 03:58:25
 Re: Re: WC final drive seals in reply to Joe M, 04-18-2003 17:55:25
I could not find the 250# grease so I used the 140#. The first time I put it together I had the hubs on the wrong axles and the grease poured out. Then I reversed them and made up 140# with some wheel bearing grease mixed up to a consistency of probably 300# and it will drip a little bit once in a while.
