AC Backhoe:
Dick
04-17-2003 23:21:42
Recently bought an AC Backhoe that appears to be a D-14 with a bucket on the front and a backhoe on the back. I'm quite sure it's a D-14 since I have another D-14 and they seem identical. I'm wondering what make or model the hoe and bucket are,, since I can't find any tag on either of them. I would like to get a manual on the backhoe but don't know which one I have. The whole unit is painted yellow and was previously owned by the state.. Everything seems to work good but would like to have a manual. Any help would be appreciated.. Dick
Gerald
02-03-2004 16:33:57
 Re: AC Backhoe: in reply to Dick , 04-17-2003 23:21:42
This coud be a 615 Ihave 2 units in service today I have complet manuals on tractor / hoe /loader if you need copys
Dick
04-22-2003 21:50:04
Thanks for the information A. McIntosh amd Ric Ks. I'll see what I can find out. I'm afraid I'm out of luck on the tag that would be found on the back of the seat because the seat for the hoe has been replaced. Both of your helpful comments were much appreciated..
Thanks,
Dick
A. McIntosh
04-20-2003 06:30:53
Several years ago I restored a D-15 Idustrial. It
had tags on the hoe and the front end loader. The Henry Manufacturing Company was the manufacture of the equipment. The hoe I have is a Henry Mark IV and the loader is a TS-500. I got lucky and found an original manule out of Canada As far as I Know there are no reprints on the market. And the farm stores can't help because it's an industrial.
The ID tag on mine is mounted on the cross angle behind the seat pop rivited on the hoe
The ID tag on the loader is on the top support right side along motor in front of the hydralic resivoir. If you sand the side of the hydralic resiviour you may be able to see the original TS-500 emblem
under the layers of paint. They were stick on lettering about 3 inches is height.
Good luck with the yellow it's hard to find.
Ric Ks.
04-18-2003 14:05:12
I believe its called an I 600 or an I 400 with back hoe attachment. its the same as a d14 with a square grill
