Re: Best pasture fence mower for WD
Scott
04-17-2003 09:43:43
Acutally, the behind sickle is good for going arround trees and fence posts. It does get a little tricky some times, but with the mower behind you, if you swing the front end toward the obticle just before the mower hits it, the bar will swing out, go past the tree/post, and you straighten up. I can't immagine being able to get through our pasture gate with the bar down if it was side mounted. When you swing right, it goes right instead of left. Then I back hard left, then right, then forward through the gate with the bar. That said, I've had more than my fair share of neck cramps :)
