1940 B Water in the oil HELP!!!
Rich P
04-17-2003 09:40:22
I changed the oil on my B and found what appeared to be water in the oil. At first I thought it was just condensation as the tractor didn't get used much last year. After I got done with the oil change I fired it up and after a couple minutes I saw an oily water mix dripping out of the clutch housing. Is this possibly a head gasket problem? It runs very smooth and has good oil pressure. the drip is about every ten seconds or so. I have never split this tractor in half is there something in there that could also cause this sort of problem? I would appreciate any help. Thanks, Rich
CHALMERSBOB
04-17-2003 19:21:02
 Re: 1940 B Water in the oil HELP!!! in reply to Rich P, 04-17-2003 09:40:22
IF IT IS A VERY SMALL LEAK, AS YOU DESCRIBE, PUT BARSLEAK IN THE RADIATOR. IT WILL SEAL IT AS WELL AS LUBRICATE YOUR WATERPUMP BEARING AND SEALS
BOB
steve
04-17-2003 15:46:07
--pull the valvew cover and see if the freeze plug in the middle of the head is leaking
--pull the oil pan and see if the o-ring seals on the cylinder liners are leaking
--pull the head and replace the gasket.
--do things in this order. you may have to put a couple psi on the radiator or let it set overnight, to find a very small leak.
