Allis Chalmers Model D Grader
Randy Ries
04-16-2003 09:18:16
I have one with a siezed motor.What motor fits,where do I find one,also need a repair manual.I use it for grading driveways and small parking lots.Worked great untill an x employee abused it.I am located in Mn. used to be alot of dealers around, now they sell lawn mowers and weed whips.
Phil Munson
04-16-2003 14:49:16
 Re: Allis Chalmers Model D Grader in reply to Randy Ries, 04-16-2003 09:18:16
The 226 was first used in the WD-45. Later it was used in D-17s and finally the 175. It is a great moter. Also the 201 WD and WC engines would bolt in.
allisguy
04-16-2003 13:53:18
For used Allis parts, engines, information and etc. contact Larry Swenson in Easton, MN. Ph. 507-787-2338. He requests that you call before 10:00 PM CDT and not on Sunday. (E-mail [email protected]) He is a real good guy to do business with.
regards, allisguy
Bruce
04-16-2003 13:04:58
Click 'Tractor Manuals', make sure 'Allis-Chalmers' is in the first search box and type 'D' in the second box, they click on Search. You should see a service manual offered for the grader. The Agco dealers here in rural MN still stock or can order lots of parts. I've never tried to get grader parts, but it is worth a try.
Unimog
04-16-2003 10:58:00
The model D used the AC G-226 engine rated at
58hp. Same engine used for diesel as well when
they came out in 1954.
JMS/MN
04-16-2003 09:35:52
Check with your AGCO dealer for AC parts. Where in MN are you- granted, fewer dealers around now, but you should still be able to get parts and service, and not have to switch engines.
JMS/MN
04-16-2003 09:35:22
Randy Ries
04-16-2003 14:42:09
 Re: Re: Allis Chalmers Model D Grader in reply to JMS/MN, 04-16-2003 09:35:22
I live in Hanover, MN., in Wright Co. I own a small asphalt paving co. I don't know much about Allis Chalmers Model D Graders. What other tractor motor is a swap to this one. There are plenty of JD and Case dealers in the area.
JMS/MN
04-17-2003 05:43:30
 Re: Re: Re: Allis Chalmers Model D Grader in reply to Randy Ries, 04-16-2003 14:42:09
Your closest AGCO dealer might be Lano's in Norwood. 952-467-2181.
DanD.
04-16-2003 16:30:02
Go to AGCO's website and use their find dealer function to find the nearest AGCO-Allis dealer.
Scott
02-09-2004 15:33:43
 Re: Re: Re: Re: Allis Chalmers Model D Grader in reply to DanD., 04-16-2003 16:30:02
I am looking for info on a G226 allis engine.My casting number is not all visible.What I have reads 8518 GA (first part is missing.the other side reads U3019-31 .any info on this engine or a Model D Allis Chalmers grader would be helpfull
BW
04-16-2003 19:21:24
In MO. our JD dealers can get AC parts ,& some times are cheaper than AGCO.
