D-14 Starter
D 14 Dan
04-14-2003 07:26:42
I've got an 1958 D-14 in which the starter does not always engage. when you turn the key to start it just whirls. Then if you rock the tractor in gear it will make the starter gear engage with the flywheel and then it will start. My question is, do you think the flywheel ring would be worn or do you think that the bendix gear on the starter would be bad? It doesn't do this every time that you start the tractor but it is starting to get annoying and would like some other thoughts on the matter.
Thanks in advance for your comments.
D-14 Dan
JMS/MN
04-14-2003 21:59:13
 Re: D-14 Starter in reply to D 14 Dan, 04-14-2003 07:26:42
Bendix problem- can't be a ring gear problem, because the bendix doesn't throw out the engaging gear far enough to hit the ring gear.
Bruce
04-14-2003 08:10:02
Sounds similar to my D-14 starter problem. It kept getting worse over time. Turned out to the be bendix gear had a little wear. It didn't take much wear for this to be a problem. My Agco dealer had a new one in stock. Don't remember the cost - but it wasn't bad (much better than listening to the starter 'zing').
