WD steering saftey warning
dave
04-12-2003 19:29:33
I just got to thinking about a year ago I was backing up very slowly with a snow blower on my WD. Without any warning the front wheels got a mind of there own like the little mother in law does sometimes. What happened is the pin that goes through the shaft near the steering U-joint broke. I did not hit anything, they were just worn pretty bad. May be a good idea to check yours, especially if you use road gear.
Bob
04-13-2003 17:26:51
 Re: WD steering saftey warning in reply to dave, 04-12-2003 19:29:33
I was driving my friends WC on the road a few years ago when the pin fell out of the steering shaft at the knuckle-----having learned to drive on a WC I naturally pushed the clutch and worked the left brake to keep from entering the right road ditch. Sure makes one think what possibilities exist.
howster, Oh darnie shuckins
04-13-2003 11:50:35
thanks for the warning.. anything can break. several years ago i was running a green tractor on a loader and when i pushed in the clutch something snapped and that was all. (turned out to be a 5/16 bolt in the clutch) i quick pulled the gearshift into nuetral and got it stopped but what if i had been backing up to hook on an impliment with a man standing on the ground. be careful guys
