Re: delco generator for little C
steve
04-07-2003 19:30:22
the third brush is connected to the field terminal and is adjustable. the main brushes are the A terminal, and the main ground brush. when checking the generator output, always ground the F terminal to the case, then measure the voltage across the A and F terminals. you can do this without the regulator or battery connected.
--go the the "research page" and "articles", then skip down to "3 brush generators" or see the link below. good reading.
http://www.ytmag.com/articles/artint4.htm
