Oil pressure gauge WD
Greg Soderberg
04-07-2003 18:53:01
I think my 1951 WD has the original oil pressure gauge. Do oil pressure gauges ever get bad?
Dave K
04-08-2003 11:31:30
 Re: oil pressure gauge WD in reply to Greg Soderberg, 04-07-2003 18:53:01
If you are not reading oil pressure, be sure you have the correct oil filter, it effects the OP readings on the WD. Correct filters are avail from AGCO for about $5.00
Dave
JMS/MN
04-07-2003 20:46:11
Yes, they can go bad, however, the WD operates on very low pressure- maybe 5-7-10 lbs, so if the needle moves upon startup, it is making pressure. Usually registers about midrange in NORMAL. If it doesn't move- check it with a known gauge.
