D19 problem
BobD19
04-06-2003 19:46:38
Hi, I have a gas D19,real good tractor but it's starting to jump out of third and fourth gear.First and second are fine. Could this be a problem with the shift rail or is it somthing farther down in. It does't pop out under load just when you go downhill and remove pressure from it.
Wally G.
04-07-2003 10:07:07
 Re: D19 problem in reply to BobD19, 04-06-2003 19:46:38
Yeah, they are pretty much known for that. You will have to split it and do some gear work in the trans. May be a bearing getting loose on the mainshaft too.
