D-14 starter
Philip Hendrick
04-03-2003 09:43:29
My starter won't engage. Is there some adjustment for this problem. The tractor has been changed over to 12 volts but probalby not the starter is this a problem. I also need some fenders and a steering wheel. It has one rust through on the flat part of the hood metal how is the best way to fix that.
JMS/MN
04-04-2003 11:20:49
 Re: d-14 starter in reply to Philip Hendrick, 04-03-2003 09:43:29
Regarding the rust spot on the hood- cut out to good metal and weld in a replacement with a wire feed welder. Low heat should not distort the metal like a stick welder would. Should grind down smooth and straight, ready to paint.
Bruce
04-03-2003 11:51:58
Just a small amount of damage on the gear teeth will keep the starter from engaging. It will just 'zing'. The starter motor is fine. You will need to pull out the starter and take off the gear assembly. Your Agco dealer should be able to get you a new one. Mine had one in stock.
