1953 WD AC front crank seal source?
Bill Lewis
04-01-2003 11:46:48
I've read some archives, but I've not found anyone mention where to find a front crank seal (w/o buying a whole gasket kit @ $100+). We pulled the old one off, but surprisingly it had no number on it. Also, the B's mentioned a centering process, I assume this doesn't apply to a WD. Incidentally, this WD has had a -45 conversion kit done to the pistons and crank. Thanks.
Steve in N.J.
04-01-2003 16:20:58
 Re: 1953 WD AC front crank seal source? in reply to Bill Lewis, 04-01-2003 11:46:48
Bill, I have seals in stock for just for the AC machines. There are two different ones though for front crank seals on the WD45. WD45 thru eng. ser#45-16649, and WD45 from eng. ser# 45-16650 on the gas engine. Also, a "Speedi-sleeve kit is available if there's some wear on the front crank snout. Not sure if I have the Speedi-sleeve, I'm not at the shop right now. Drop us a line if interested...
Steve/B&B Custom Circuits
Bill Lewis
04-01-2003 11:50:11
Incidentally, I'm in greater Detroit, MI and the tractor is in Central Indiana. I have a former John Deere mechanic doing the work; hope that green paint don't rub off!
