front wheel bearings for AC G
Jack Parham
03-27-2003 19:25:05
Does anyone know of replacement part numbers or source for "G" front wheel bearings and seals. The outside bearing is a timken and I have the number for it but no information for the inside bearing or the seal. Help! Thanks. Jack
AWB
03-28-2003 08:06:26
 Re: front wheel bearings for AC G in reply to Jack Parham, 03-27-2003 19:25:05
Jack: Take the bearings and seals that you have and take them to a bearing supply house. Usually they can fix you up if they can get a number off the old bearing or seal. They can usually measure up the others and send you home with what you need, or order it for you. If you don't have a bearing supply house close , let me suggest Allied Bearing Supply in Oklahoma City, Oklahoma. Give them a call..you may be able to send them your old parts and fix you up that way. I have bought a lot of bearings and seals for antique tractors from them and haven't been skunked yet. Hope this will help you out. AWB
