Can I use a C engine on a WD frame?
Paul
03-27-2003 15:08:38
A guy has told me about an old small Allis grader that should be able to be picked up fairly cheap. I looked at it from the road and thought it was based on a WD, but could be a C-model powered - I couldn't see it well enough. It has a bad motor, but I have a good running C that I don't use much, so can someone tell me if it's very feasible to put my motor on the grader, even if it turns out to be WD-engined originally? What's involved? Thanks very much.
reuben
03-27-2003 20:01:15
 Re: Can I use a C engine on a WD frame? in reply to Paul, 03-27-2003 15:08:38
I've done some AC motor swaping. I would advise against putting a C engine in a WD frame. This would be way under powered. The bell housing bolt patteren is also different, an adaptor plate would have to be made
Tony C
03-27-2003 17:18:45
If it`s a wc grader, or a D grader it needs a 201 or a 226 engine not a 125 cu incher. Email me or call for more info. Tony
Paul
03-28-2003 06:23:14
 Re: Re: Can I use a C engine on a WD frame? in reply to Tony C, 03-27-2003 17:18:45
I looked at it again last night, and it looks exactly like the one in the "Tractor Photo" archives of the 1949 Allis Chalmers W Speed Patrol. So would that have a 226ci motor? Is that the size of the WD45 motors?
steve
03-28-2003 16:05:40
 Re: Re: Re: Can I use a C engine on a WD frame? in reply to Paul, 03-28-2003 06:23:14
same block, the early WD had different stroke on the crank than the later WD45 and D17.
--Speed Patrol is a good collector tractor, get it.
Noly
03-27-2003 15:31:11
It is probably on a WC frame. I don't know if the motor swap would work or not.
H.B. Hutchens
03-27-2003 17:26:44
 Re: Re: Can I use a C engine on a WD frame? in reply to Noly, 03-27-2003 15:31:11
If it's aWC grader, would this make it an RC grader with a C engine. Would be underpowered but unique. H.B.
