HELP! WD45 bogged down missing
Michael
03-27-2003 06:06:40
I recently had a tune up done and was doing some early season mowing. As I went thru some very heavy grass the tractor started to bog down very quickly. I pushed in the clutch just before the tractor started to die. The tractor didn't die but started missing severly and would barely run. IF I backed off the throttle at all it would die but with the throttle wide open it would run so rough that the tractor would barley move. WHAT HAPPENED? and what do I need to do to fix it?
dave K
03-30-2003 11:11:57
 Re: HELP! WD45 bogged down missing in reply to Michael, 03-27-2003 06:06:40
My WD did that, bad condenser in the mag.
Michael
03-31-2003 07:36:39
 Re: Re: HELP! WD45 bogged down missing in reply to dave K, 03-30-2003 11:11:57
Thanks but mine has a distributor
Wally G.
03-28-2003 15:00:49
Start by resetting the points and make sure the breaker plate isn't moving around.
Michael Rolnick
03-31-2003 07:37:40
 Re: Re: HELP! WD45 bogged down missing in reply to Wally G., 03-28-2003 15:00:49
Thanks!
Rob
03-28-2003 11:31:41
Check the points. I had my "C" do that and the points were loose. I took the gas tank off, cleaned and sealed it, went throught carb about
5 times before we found the points problem. The screw that holds the gap was loose and that
caused all the problems.
Michael
03-31-2003 07:39:09
 Re: Re: HELP! WD45 bogged down missing in reply to Rob, 03-28-2003 11:31:41
thanks!
Bruce
03-27-2003 16:11:28
Also could be dirt in the carburator broke loose when got into hard pull. Might have to clean and rebuild carb.
Dave
03-27-2003 07:43:51
clogged fuel line somewhere???
Michael
03-27-2003 09:37:22
 Re: Re: HELP! WD45 bogged down missing in reply to Dave, 03-27-2003 07:43:51
THanks, I'll work on clearing the line & let you know if that helped.
