WD-45 Light Switch
Dave (NE)
03-25-2003 06:50:40
According to the amp meter, my battery is not charging on my WD-45. I had
the generator spun and it tested out good. They suspected that the light
switch is probably bad but indicated they cannot be purchased anymore.
Does anyone have any other ideas of what else could be the problem, or
have a new old stock light switch in box for sale.
Steve in N.J.
03-28-2003 06:28:24
 Re: WD-45 Light Switch in reply to Dave (NE), 03-25-2003 06:50:40
Dave, I rebuild/restore the OEM Headlight/Charging switches. If interested they run $40 exchange w/o knob, $45. w/knob. If you already purchased the aftermarket one, I buy the old switches....
Steve/B&B Custom Circuits
Dave (NE)
03-27-2003 10:41:12
Thanks for all of the good advice and where I can obtain a replacement switch. I'll be working on it this weekend and I appreciate the assistance. Dave
odis
03-26-2003 20:44:39
The local AGCO dealer says they are available new from AGCO for $60.Hope this helps
Duey (IA)
03-25-2003 20:39:03
Dave,
Your generator will not charge if the gauge and switch box is not grounded. The resister on the light switch is what controls the charge rate and it can not work unless grounded. Duey
Dave Wi.
03-25-2003 13:56:47
I had a link for new 3 position light switches,when i find it I'll post
I need 2 myself
Dave Wi.
03-25-2003 14:20:56
 Re: Re: WD-45 Light Switch in reply to Dave Wi., 03-25-2003 13:56:47
found the place Walts Tractor Parts they have new 3 position switches for $62 plus ship.
Dave (NE)
03-26-2003 06:31:19
 Re: Re: Re: WD-45 Light Switch in reply to Dave Wi., 03-25-2003 14:20:56
Dave, did you have a phone number, web site or email address for Walts Tractor Parts? Thanks everyone for the great help.
Dave
Dave Wi.
03-26-2003 11:49:29
 Re: Re: Re: Re: WD-45 Light Switch in reply to Dave (NE), 03-26-2003 06:31:19
here try these www.waltstactorparts.com/acatalog/
or you can email [email protected] they can give you the link if I'm wrong,also if you need help with wiring ask for Duey IA, he has a page with wiring diagrams.
Dave Wi.
03-25-2003 14:20:47
Dave in Mo
03-25-2003 09:43:48
Did you check the fuse on the backside of the switch? I thought I needed a new one too, but just took the old one out, cleaned it completely up, and it works great now. Check the archives at left for sources. I think Norm at Sandy Lake Implements have them too, now.
DanD.
03-25-2003 13:07:37
 Re: Re: WD-45 Light Switch in reply to Dave in Mo, 03-25-2003 09:43:48
The fuse on the back side of the switch is only for the lighting circuit. It has nothing to do with the charging circuit.
