Rear Rim for B Allis
Glenn H
03-24-2003 06:27:53
I have a B Allis (1957) that needs a new rear rim. The only problem is I don't know whether it is a "original ridge (bevel) type" or "four loop rim." If anyone can tell me the difference, I would appreciate it. Thanks!
Dick L Pic
03-24-2003 16:42:51
 Re: Rear Rim for B Allis in reply to Glenn H, 03-24-2003 06:27:53
This is the original ridge type rim mounted on the B hub.
steve
03-24-2003 16:01:08
the original rim is the ridge type and has 4 cam locks that wedge the tirm around the wheel. the "loop" type has 4 small loops welded to the rim that you stick a bolt thru the loop and pin it to the hub. either will work if the "loops" are setup for a C or B tractor. these were more common with "other" tractor manufacturers.
