WD-45 overall weight
Donnie
03-22-2003 16:54:17
Does anyone know what a WD-45 widefront weighs without implements? It has 13.6 x 28 tires on it if that makes any difference. Thanks for any help.
Donnie
JMS/MN
03-23-2003 09:00:36
 Re: WD-45 overall weight in reply to Donnie, 03-22-2003 16:54:17
Standard size tire was 12-28 (now marked 13.6-28. It was common to go with the oversize tire: 13-28 (now marked 14.9-28). Shipping weight was around 4400 lbs.
Joel L
03-23-2003 18:51:08
 Re: Re: WD-45 overall weight in reply to JMS/MN, 03-23-2003 09:00:36
Why did the Nebraska test WD45 use 14.9x28 tires? I assumed that was standard size.
JMS/MN
03-23-2003 22:10:47
 Re: Re: Re: WD-45 overall weight in reply to Joel L, 03-23-2003 18:51:08
I'm reasonably sure that if you check the operator manual for specs you'll find the 12-28 was standard. Granted, you don't see many with the smaller tire, because the 13 inch option was a big advantage to gain traction. I have a WD manual, not the WD45, but if memory serves me correct for the one that Dad bought in 1956, the 13 inch rubber was considered oversize.
Joel L
03-22-2003 21:24:56
Seems like small tires. Stock, I'm pretty sure, were 14.9 28. Mine weighs about #4,000 without any fluid in tires.
Dave--- Mich
03-22-2003 17:23:31
Depends if the tires are loaded or not. The shipping weight from the factory was 4400# but I'm sure that was with tires loaded.
Dave
