Loaded tires on a wd45
ksmith
03-22-2003 16:45:36
Just wondering if I need to load the tires on my wd45. I'll be using it for baling, pulling wagons, mowing with a seven foot flail, pulling a 8 foot disc, maybe plowing with a two furrow ... maybe a three. Does this type of work warrant loading up the tires?????
Thanks in advance
Kevin
Wally G.
03-23-2003 04:56:59
 Re: loaded tires on a wd45 in reply to ksmith, 03-22-2003 16:45:36
Yeah, you want to load the tires. You won"t believe the difference it will make especially when you get a load of hay or silage behind you. Think about stepping up to 16.9x28's off a D17. Worked real nice on ours.
big orange
03-22-2003 17:04:30
When we plowed with a 45,used fluid to valve stem level and 2 sets of wheel weights.
