Oil bath air cleaner
Muffy
03-19-2003 20:48:01
I have an Allis B-1939, and it has an oil bath air cleaner, how full do I fill the bowl, it has a reservoir inside the reservoir, do I fill the outer reservoir only or both the inner and outer??? Thanks again for all your help. Muffy
JMS/MN
03-21-2003 00:00:39
 Re: oil bath air cleaner in reply to Muffy, 03-19-2003 20:48:01
The OPERATOR manual has all of the details for this , as well as many other important things you need to know to own a good tractor.
Muffy
03-21-2003 15:02:39
 Re: Re: oil bath air cleaner in reply to JMS/MN, 03-21-2003 00:00:39
I would love to look in the owners manual, but alas I do not have one, can anyone tell me where I might find one???? Muffy
dave K
03-21-2003 21:51:58
 Re: Re: Re: oil bath air cleaner in reply to Muffy, 03-21-2003 15:02:39
Manuals are listed right here on this forum, on the left menu!!
Dave
rudy
03-21-2003 16:56:45
e-bay
DAVID C.
03-20-2003 06:53:00
Good question. I am curious about that too. I just recently serviced mine and re-filled the whole reservoir to ring indicated on outside of cup. Now when I stop the engine off oil leaks out of the cup and I'm wondering if I've made a mistake and if so how it should be filled.....
Any help out there?
Bryan Smith
03-20-2003 13:36:18
 Re: Re: oil bath air cleaner in reply to DAVID C., 03-20-2003 06:53:00
Usually you fill both inner and outer "rings" as you call them, up to the top of the inner ring wall. On the AC's I have tah is usually filling them up to a kind of lip or ring pressed in the cup outer wall. I don't remember where that is on my WD 45, but on the B / C / CA it's very obvious. On them I think the level is approximately 1/2 inch down from the top lip of the cup (maybe a little more or a little less). Hope that helps.
