Removing Muffler from Allis-Chalmers G
Phil Leckrone
03-18-1999 17:26:26
I need to replace the muffler on an Allis-Chalmers G. It is basically a pipe nipple threaded into the engine manifold. How is the best way to remove this pipe nipple from the manifold without cracking the manifold. If you have done this before, any advice would be helpful. I need to replace it with a new muffler.
Dan D.
03-19-1999 11:21:36
 Re: Removing Muffler from Allis-Chalmers G in reply to Phil Leckrone, 03-18-1999 17:26:26
Get out your torch, get the manifold glowing bright orange hot all the way around the pipe, then get on it with a little pipe wrench or good vise grips right close to the manifold. Then when you put on your new muffler, put it on finger tight and loosen it and retighten a couple of times a year. Also, be sure to get your new muffler from AGCO. About $15 than less than an aftermarket place I found.
