Hotter \ colder plug?
RG
03-18-2003 18:12:36
I have had a wd -45 for several years, and I am constantly haveing to replace the spark plugs. I have tried several different brands some work better than others but none last more than a summer. I have naturally checked (and replaced) the other ignition components. When doing all this diagnostic work I have found that the heads have apperantly been shaved by a previous owener all cylinders have 180 psi compression +\- 3 psi. I have allways replaced the plugs with original heat range of plugs, could this be my problem? Do I need a plug in a different heat range?
Thanks for any replys
RG
Doug in OR
03-23-2003 19:09:00
 Re: hotter \ colder plug? in reply to RG, 03-18-2003 18:12:36
Tell us more of what the plugs look like. If the plugs are just wearing out, changing the heat range won't help you. In this case, go to platinum plugs. If the plugs are getting carboned up or fouling, then switch to a hotter plug. If there is "blistering" on the insulator, then try a cooler plug. If your plug is too hot, you might also notice detonation, but that's not always a sure-thing.
One note of caution - cross referenced plugs may or may not be of the same heat range. This is an issue with many older tractors where the original plug number they specify is no longer available.
Phil Auten (TX)
03-19-2003 10:27:06
RG,
I am using Autolites in my A-C B and RC because they are specifically recommended for mag ignited engines. Currently, Autolite 295 plugs seem to be working the best in these two. Neither tractor sees any heavy work, so this should work fine in most tractors. If your tractor smokes a bit from worn engine parts, you might ask the parts man for plugs that are a heat range or two hotter, if available. This should help prevent fouling from oil deposits. If the carb is adjusted properly, the 295's should be fine. If these foul from excess fuel, try leaning out the idle and/or high speed mixture to stop the fouling.
Phil
