B governor question
Ken
03-18-2003 07:48:21
My B surges every time I start her up. I see in the manual, a surge spring in the carb parts picture. Is that spring the only way to stop engine surging? If so, can you explain where it hooks up to? Thanks, Ken
Rod (NH)
03-18-2003 11:42:25
 Re: B governor question in reply to Ken, 03-18-2003 07:48:21
Hi Ken,
There is a "surge spring" on the B. It is a fairly light spring that installs in a vertical position between the governor shaft that goes to the carburetor throttle valve and one of the manifold studs. There is a small hole drilled horizontally in the governor shaft just forward of the carburetor for this spring. See the link for a picture and a discussion on this spring.
Rod
