WD, TRICYCLE FRONT END LUBE
MIKE DAVIS
03-17-2003 03:25:10
THE BOOK TELLS HOW MUCH LUBE THE FRONT END TAKES BUT NOT WHAT TYPE OF GREASE/OIL IT TAKES. WHAT DOES IT USE? THANKS!
Brian G. NY
03-17-2003 05:26:16
 Re: WD, TRICYCLE FRONT END LUBE in reply to MIKE DAVIS, 03-17-2003 03:25:10
The Allis manual specifies 140 gear lube for NFE and 250 for WFE. "Maintain oil level so worm gear is one third submerged". This is under the "Lubrication and Service Guide" section under the 30 day check heading. The seal in my WD leaks so I have mixed the gear oil with Ford automotive wheel bearing grease to a semi liquid state which works quite well. Sometime, when I get a "Round Tuit", I will replace that leaky seal.
