Hub duals (3and 5/8s) or 92mm ?
Kim
03-16-2003 20:23:10
I want to put hub duals on my AC 220 with 3 and 5/8s axel. Will hubs of a john deere 7800 fit ? they have a 92 mm axel. thanks
Gatz
03-17-2003 08:56:06
 Re: Hub duals (3and 5/8s) or 92mm ? in reply to Kim, 03-16-2003 20:23:10
Kim, just doing the conversion.... 92mm = 3.622
3 5/8 = 3.625 or .003 Difference on diameter. Because the JD hubs are (nominally)smaller than the AC axles, they'll end up being an "interference" fit which may or may not be a problem. Worth a try if you can return the JD hubs if they don't clamp up correctly. btw, the conversion factor is mm/25.4 = inches. Gatz
