ALlis wc question
david
03-15-2003 18:44:12
Hi guys i just bought a stlyed wc tractor from an older lady and i am a MM man dont know much about A-C but im getting water in the oil a lot of water! Is it the head gasket? Do the sleeves have o rings around them? If so do these go bad often? Thanks!!!
Farmall Daddy
03-23-2003 16:48:51
 Re: ALlis wc question in reply to david, 03-15-2003 18:44:12
Many problems could be with it. Might have set outside, and got water down the muffler. O ring may be shot. The major thing would be that there is a crack in the block that is letting water in. Change the oil, run it for about two hours and then check the oil again. If water comes out in large amounts, you have a cracked block. Hope you don't have to much trouble with it, hate to see a tractor end up in the scrap yard.
steve
03-15-2003 19:05:23
could be either, yes they have o-rings. pull the spark plugs and look for a clean one. the clean one will be burning water= head gasket. Pull the valve cover and look for leaking freeze plug. pull the oil pan and look for dripping below the liners for o-ring problems.
