THREE POSITION SWITCH, (WD) 12v CONVERSION
MIKE DAVIS
03-14-2003 04:23:57
CAN YOU USE THE ORIGINAL THREE POSITION SWITCH, "LIGHTS AND CHARGE SWITCH" WHEN YOU CONVERT TO 12V? I HAVE THE MANUAL WHICH SHOWS 6V WIRING AND A DRAWING SOMEONE PASSED ON FOR 12V, IT SHOWS AN IGNITION SWITCH INSTALLED.THANKS.
Steve in N.J.
03-14-2003 06:37:08
 Re: THREE POSITION SWITCH, (WD) 12v CONVERSION in reply to MIKE DAVIS, 03-14-2003 04:23:57
Mike, You could use the switch if you remove the resistor, (and some folks probably have) but because of the higher current flow through the switch, I wouldn't recommend using it. Use a 12V/15/20amp rated switch that's fused and designed for higher current flow so the switch doesn't heat up and has the fuse for circuit protection. We have the correct switches in stock that we use for our 12V conversions if interested...
Steve/B&B Custom Circuits
JMS/MN
03-14-2003 05:30:30
If the 12V conversion is done with an alternator, the charging rate is controlled by the alternator, not the switch, so it would be eliminated. I imagine you could still use if for turning the lights on if that portion was wired properly.
