Wd-45 clutch adjustment
wade
03-13-2003 04:12:40
I am posting this for a friend of mine. He put new throwout bearing, pressure plate and clutch in. He has 1/2 inch of free play on clutch petal. It grinds when going into forward gears and worse in reverse. What more does he need to adjust.
Duey (IA)
03-14-2003 21:47:38
 Re: wd-45 clutch adjustment in reply to wade, 03-13-2003 04:12:40
Wade,
Tell your friend that the book says: set the length of pedal rod so pedal has 1/2" to 1" free pedal travel measured at the frame channel-top side. Also be sure the pressure plate fingers are all the same distance from the throw-out bearing. Duey
